Fuel Sump??
dmaxman06
May 25, 2011
493
morenci az
i have one of the beans diesel pickups havent installed it yet but i like them over all the rest they come with a hole saw and use 1 bolt so no extra drilling and they have a 1/4 inch plug so if u need to drain your tank you can im not trying to sell beans stuff i just think there a little more better thought out then the rest i have seen
PACougar
2,105
41
El Dorado Hills, Ca
I have one of Beans I need to sell, they are definitely the best design. I don't think you could ever have it leak.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Do you have any problems with it freezing up? I guess it can't be any worse then having my fuel filters freeze up.
Why would it cause any issues? Your fuel lines are metal, fuel cooler...
Your filter is gelling from the filter media, not because they are made of metal.
I just bought it but I know it will not be a problem. My truck regularly see's -40F and lower.
My main reason for this, is getting every last drop of fuel out of the tank if needed... I have been in the middle of BFE nowhere and needed every ounce to get home lol.
TRUBBS
461
I'm doing dual sumps with -12an feeds to the lift pumps. The pump is gravity fed, so I wanted it to have all it could ever ask for. One down fall some will say is that the sump sits under the tank and can be ripped off. If that happened to mine I have worse things to worry abt. They tell you they are not intended for off road in the instructions. .. Just my opinion.
why not just run 1 sump with 2 fittings?
I bought one of these little gems, for piece of mind and I want all the fuel if it comes down to it. Sometimes leaving 5-6 gallons in the tank isn't an option...
http://www.ebay.com/itm/281255994225?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
wish that was there when i was looking for one, might just end up getting one for future use anyways
moparkxracer
2,309
33
Out and about
Some have said that with two fittings in it when fuel is low it's like flushing a toilet and will suck in air. I know the airdog removes air but why make the pumps work harder.
6,047
years ago it was suggested that 600hp was the max a stock pick up could supply for power.
its amazing how things have changed.
coldLBZ
Apr 22, 2007
2,344
Alberta, Canada
Just bumping this up. I am wanting to put a sump in mine, but I'm also curious if anyone has been having issues with the sumps in the winter. Mainly gelling or water issues.
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
904
31
Western MA
www.matpa.org
Well, I'm wondering if it's "stock" vs "stock-modified".
A stock fuel pickup was found to do a great job at draining the tank to low levels but at the same time was also found to be a restriction during high fuel demands (don't know if there is an exact HP limit), so many people modified their stock pickups to allow more flow, but in doing so may have created issues when the tank gets low.
After seeing it done in pictures and then actually doing it myself, I can see there being a HIGH level of variability from one person's mod to another that could cause some to have issues while others do not. Having to manually cut a hose to length and try to route it properly in the bucket introduces a chance for many variables. That said I mocked mine up several times and measured several times before cutting and routing, and I've run mine very low and not had an issue during daily driving (racing may be a different story but I've never tested that).
It was like the Eaton E-Lockers where several of us had Zero issues with wires rubbing, while others had failures due to wires rubbing on the ring gear bolts. The instructions allowed for variables which caught some and not others (whether by being careful or shear luck).
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I gained absolutely nothing at 1150whp going from a stock pickup tube to a beans sump. Dynoed back to back and was within 4hp.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Im on the fence about doing it. Having a hard time cutting into my "new" truck. But if I were going to do one, I'd do the G&R sump. It has an integrated return so if you're installing a lift pump, you dont have to mess around with cutting the fuel filler neck...
Ben
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Ben
I used the factory pickup tube as the return. No cutting required.
S Phinney
4,008
Quncy, Fl
Maybe you won't see mych on a dyno. You are sitting still. In the real world it can be a different maker.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Unfortunately I'll never know now since I've changed air setups also since them.
But going from a baby fass 150 to a fass 260 titanium at that power will be interesting to see if anything changes happen in the hp department.
