I thought on the lb7 is 23,000 psi or is that the maxs psi.
That is max
Parts are indeed very expensive... The cheapest thing to do first is to see if you do have air getting into the system. You can try to methods to test for this.... One is to hook up an air line to the fuel tank and regulate it down to about 12-15 PSI. It should hold the pressure but if it doesn't what you will be looking for is fuel being pushed out somewhere on the fuel system from the tank to the CP3. Common places for these leaks are the fuel filter mounting housing and the pressure port shrader valve located at the front of the engine on the passenger side.
If this method is not available to you then I would suggest installing a clear hose from the filter housing that feeds the CP3 and then you can litterly see the air flowing to the CP3 if any. Make sure your tank is full otherwise you could get air into the fuel lines from sloshing.
If you determine that no air is getting in then next would be to do a return test on the injectors. It's a major pita but it will prevent you from buying parts you don't need. Do a search on the forum and you can find plenty of good info on to do this.
If your injectors test good then next is your CP3. Try running some 2-stroke first to see if maybe its just sticking, after that I would replace the regulator.
The fact that your actual pressure is tracking right along with commanded rules out a bad CP3 almost 100%. I think personally its air getting in.
Hope you get it nailed down though.
