Continuity was good from fpr to ecm. So shouldn't I be getting some voltage from the ecm. I wasn't getting anything with the key onFPR unplugged will still allow the truck to start. You have something else going on. Possibly a sensor wire that got nibbled.
Nothing to the fpr is why I'm wondering if the ecm may have some bad spots. I figured there is more wrong. Just figure it all in the ecm. Truck fires on ether by the way.You're correct that there should be voltage, but there's something else going on too. No voltage to the regulator will just make it run full rail pressure, will still start / idle
The truck will not start unless you give it some ether and will shut off as soon as you stop spraying ether. If there is a issue with the fuel rail pressure sensor will that make the ecm not send any voltage at all to the fprDo you have a way of comparing desired vs actual fuel rail pressure while you are cranking? And if you start the truck, is the fuel pressure normal for the conditions in which the truck operates?
The fuel pump runs at full pressure all the time. The FPR is a solenoid that limits the pressure created by the fuel pump in the fuel rail. The Fuel Rail Pressure Sensor sends rail pressure info to the ECM so that the ECM can make the correct decision on how much to limit the pressure.
I understand that it will not cause a no start. My question is is there anything that would prevent the fpr from getting any voltage like another sensor or a faulty ecmbut as mentioned above that will not cause a no start condition. you have something else going on. as stated you need to scan for actual and demand fuel pressure during cranking and report back with that information
I used a common ground (negative on battery) no voltage and checked ground wire and it was making good continuity. Checked continuity on both wires to correct pinout on the c1 connector and showed good continuity. Didnt check resistance. What would be a good number for that.a short to ground or faulty ECM. the voltage should be consistent with the return being a PWM control to ground.
have you checked the voltage to a common ground and not the FPR ground pin? have you measured the resistance of either line to a common ground?
I understand all that. I'm just trying to fix one problem at a time. And right now code p0090 is the only code up. My plan was to figure it all out and hopefully whatever is keeping the ecm from getting voltage sent to the fpr will be my issue. Even if it's the ecm it's self. I don't have a computer to hook up to it. All I have is a small code scanner. I'm working on getting someone out to hook a computer up to it hopefully soon. When the truck decide to not start on me this code came up at the same time.I dont think the engine needs the fpr to run, it'll make max rail without it is what 2004LB7 is saying. Hook efi up and log FRP and DFRP see what it says while cranking.
