super diesel
<<<< Under Pressure
There are two ways to address the "lumpy idle" issue with high output lift pumps.
One is to rescale the CP3 amps the other is to lower the rail pressure in problem areas. Both accomplish the same thing, and can be done with EFILive.
Pats correct.
This is possible if it's not leaking around the slide (is what I meant). Some times I don't say thing right. I had this situation a few times and had to change the reg to control it (newer LB7 reg). Maybe mine were just to worn out (to much fuel excaping around it instead of going through it like it should).
