How much psi can I turn my 1792 up safely. I recall only being able to run 12 psi on my LLY because of the FICM correct? Since there is no FICM on the LBZ can I run 20? 30? 40? 50? psi?
If you have a factory priming pump only about 12psi before it starts to slowly weep (what I've seen anyway). Even if not, the higher pressure will start to make the truck lope at idle (my experiences saw it at about 18psi in low milage trucks). On higher milage trucks 100K+ it is even lower because of the wear in the fuel pressure regulator (unless it's been replaced recently). The fuel pushes past it and causes the lope (high fuel pressure at idle). Hope this helps.
Mine is set at 14-15psi as well. It will pull all the way down to 3psi. durring a pass.
What do you mean weep? Is there an aftermarket alternative to the factory priming pump? Can you tune that lope out by decreasing PW at idle?
I'm trying to lower my psi to the cp3, I'm at 12 and its causing my cpe to do funny things
Whats it doing?
