How many old posts of mine are you going to dig up?:rofl:
With a lb7 you can pull the hose off before the sheafer valve its a aprox 1/4" ( metric) hose behind it.
A barbed fitting will fit right on to it
I used a 10mm x #4 jic on my filter housing and it ended up craking the housing from vibrations on the fuel line( many miles later ).......I doubt that would happen to anyone else though...Just my luck
if i find some more good ones ill break out the shovel
i tapped mine right after the FF befoe the cp3.
i did notice i could have tapped it there when i replaced my cp3 but its fine where it is.
