I run my LB7s to the fuel light every time. My truck's original CP3 (290,000 miles) was only replaced because I went to a 12mm stroker when I built the motor. Suburban has the original still.
Between the truck and Suburban, I've run out of fuel 5+ times (cracked fuel pickup tube and calibration issues from the swap respectively). No problems so far.
Sent from my Cat S60 using Tapatalk
Just because you haven't had a problem doesn't mean it isn't an issue, we all know air in fuel is hard on pumps and injectors why risk it
