Hello, my 02 is telling me my tank is empty when I have used 10 miles of a full tank. Is the level sensor available separate from the whole sending unit? If anyone has a part number or information it would be appreciated. Thank you.
As a point to consider, RockAuto has the OEM fuel sender for $233, vs. $128 for just the level sensor. The flex hoses tend to crack over time, so it is worth considering replacing the whole unit, IMO. I had to replace the one in my truck when the suction hose cracked and it started pulling air at 1/4 tank. It would suck to replace just the level sensor then have to replace the whole thing a few months later.
This is true as I am having the same problem with my 01 s10 beater. Runs great until 1/4 tank then the fuel pressure start fluctuating. Just haven't felt like dropping the tank
So much easier to pull the bed
