Have fuel gauge issue, non working has fuel light on. Tested tank module with new unit, did not install. Plugged the module in and moved the float an nothing. Had dash unit tested/rebuilt. Rebuilder confirmed fuel gauge problem, replace gauge motor an no fix. Suspect maybe board crack. replaced dash clusted with dorman reman, same problem. The tank module did however operate the rear pump when in the empty position. Help with test procedures and suggestions in laymen terms please and Thanks 04 chevy duramax automatic
