Fuel filter
roxyfever
Feb 11, 2016
191
terrell tx
You dont have to delete doesnt hurt to keep it in there. Just extend its change interverals. If it was me id get the fass delete bowl for factory spot then just it case i would need to i could still prime the system
DmaxDrew
Dec 24, 2014
110
Texas
Thanks for the info. One more question. If my Fass system stops will it still filter the fuel? Will the cp3 suck it through the Fass system if its not working? A little confused.
kiwilml
454
Uh my cp3 works just fine pulling through my fass 150. I had a fuse blow the other day and I ran for a couple days just like normal so you shouldn't get stranded because your lift pump quit.
And I would think it'd still filter like normal too..
Awenta
4,090
They are flow through by design but sometimes they don't flow so well
kiwilml
454
True, I watched my rail pressure and made sure it stayed close to desired and was easy on it and never noticed any difference.. I'm sure it wouldn't have held pressure if I woulda stomped it on my big tune..
1,865
They are only "flow-thru" under part-throttle regular driving conditions. Not great when getting on the highway, though.
But definitely not at WOT.
drperry
Jan 4, 2015
21
Also helps to unhook the power, if the fuse didn't blow. If it's the electrical side of the motor that crapped out, having power to it can lock it in place.
You'll still be pulling fuel through the FASS filter, but might as well as keep the stock filter and double the mileage between changes, or whenever the truck tells you to.
Extra filtration is a good thing. Especially for me, since I have the CP4, lol.
nick31
Apr 14, 2016
32
Have my stock filter and housing/lines all completely removed. If you have the factory filter still in place it is supposed to flow through, but when mine went down last winter it would not flow through and I was stuck on the road, that was when I still had the factory setup and a cp4. Now have a cp3 and my fass feeds directly to my cp3, so if my pump dies again the truck will just die, no vaccum in the system anymore.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
When a gear rotor positive displacement pump like the FASS or Airdog quits disconnecting the power supply will not make a bit of difference for the fuel to flow through the unit.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,195
360
At Da Beach
I left my stock filter. I have 45k on my LML already and still haven't changed the fuel filter. I did the same thing on my LMM and cut the filter open once, it looked brand new inside, air dog caught all the trash and water. Just leave it on the truck...
jlawles2
1,057
39
Danbury, TX
I left the factory head installed. Worst case if something happens, you can always bypass the FASS with a hose connector and be back on the road.
outtatimexx
Aug 21, 2017
21
Perry, Ga.
Hi; I know this is an old thread, but I have a question. I have an "02 LB7 stock. If I go to a Fass system, can I just simply leave the 3 micron Donaldson filter on the stock filter housing? Is this too much filtration? Or should I buy the filter delete setup and leave the primer in place? Thanks!
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
You can leave it. Just change the filter when you install the fass and forget about it..
