fuel filter re location?
06dmax
Aug 5, 2009
295
I want to clean up the side of the motor a little bit so I was thinkin of relocating the stock filter housing back with my air dog raptor pump do able or what ya think?
AdaMax
Nov 26, 2010
412
Caldwell , Oh
I just removed mine being that I have the Air Dog filters . I just wonder if it will set a code without the wires hooked up on the filter housing .
quadracer37
Mar 31, 2009
547
northern, IL
If you remove the stock filter completely make sure you are running a 2 micron filter on your fuel pump setup!!
Fass titanium series is only a 7 micron and that is not good enough!
gmc502
466
12
the napa 3422 filter is a pretty good fuel/water seperator,and it has a water sensor in the bottom.comes w/ a 2 micron rating.it what i'm using.
06dmax
Aug 5, 2009
295
FOr the time being I was just gonna take the whole housing and everything and just bolt it to the frame back by my pump
