Fuel filter problem
15,681
233
My fuel filter has been on for 6K and I buy my fuel at a truck stop that mves a lot of fuel. Lately my truck has been feeling sluggish and blowing more smoke than before. Yesterday I changed the fuel filter for the hell of it and when I left the shop the truck ran like a raped ape. This morning I cut the filter open and saw that the outer pleats were black ( restricted ) and inner pleats were like brand new. I think we are going to have to change these new filters more often. I don't think 10K is acceptable anymore.
mike
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
I will make sure to tell the boss :D
PS- When do you sugguest to change the rear axle fluid in Wendy? and when it's time will you do it and I can buy another pretty diff cover from you?
:witch:
02freighttrain
Team Salad Bartender
Aug 13, 2006
911
sootville, Fl
Mike, I'm changing mine about every 2,000 miles just because I had some fuel supply issues (no more, I hope) I buy them 3 at a time. Anyhow, I use a filter made by Racor/Parker. It's about 1 inch longer than a NAPA Gold or stock filter. They seem to flow well and the claim is that they are well suited for trucks with modified tunes. The Part Number is "PFF5544". The extra length causes no problems with install. The filter is also suppose to have a better filter paper that catches any water better. They call it "Aqua-Bloc" paper. Sean8816 is running them also. Google the part and you'll find more info.
15,681
233
:witch:
Kat
Change it before 5K. I have everything in stock so you can wait for it. About an hour. I am going to do the fuel filter at every oil change from now on.:baby:
WSUcowboy
500 club baby!!
Aug 7, 2006
512
Spokane, WA
Does this filter go in the stock location????
15,681
233
Thanks for the info.:D
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
Kat
Thanks :hail: Mike
I will call you tomorrow to sch. a time :D
:witch:
hdmax
Mini-Max
Aug 9, 2006
190
New Lex, Oh
mike
I would think that the new 15 PPM Diesel would allow us to run the filters much longer then with the old 550PPM fuel.:confused:
Skyhigh4by
Goin to Poochisloose
Apr 13, 2008
408
Powell River, BC
Pretty much any marine diesel I have seen runs a raycor/parker filter. I put one on my old VW diesel and it worked great. Easy to find at marine parts stores.
Noreaster
2,910
Cape Cod,MA
Ive been running the PFF5544 for awhile, same filter with a different name from everywhere else. The double pleat filters are longer than the old single pleats.
http://www.blinefilter.com/store/in...=13989&zenid=7bcafd903afef87261b8ebd0f4c810af
Probably better off deleting the stock filter setup & running a 2 or 3 stage Fleetguard setup underneath the truck. We run 30/10/2 micron filters on the big boat, alittle overkill for a 16v92 detroit that would burn anything.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
mike
Are you running a GM/AC Delco filter?
I would use the blue ones instead of the white, I cut one of each open after use and the blue had 4 sections of the pleats black and the white only had 2 sections. Also at the top of the filters that blue had 4 openings for fuel and the white only had 2
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
I went to the dealer just today to get my fuel filter to fix my trans issue. I know one of the parts guys and he looked up the service bulletin and told me the upgraded filter is the white one. I asked for a blue one, they didn't have it. I know the white filter I have on the truck has not lasted as long as the blue one that was on it previously. Also noticed the blue one had three rectangle holes at the top where the white has many small round holes at the top. Don't know if that makes any difference.
The one mechanic in there said GM changed the filters due to filter longevity, something about the blue filters didn't last as long as GM said for scheduled maintenence, seemed opposite of my findings. So they introduced one that lasts even less.
