Fuel filter housing
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
Could a leak in the filter housing cause the truck to "rattle" more? Seems like I had a rattle that I thought was in the tuning, I changed my fuel filter 2 days ago and the truck quieted right down, last night I notice a slight rattle again, I cracked the bleeder, not alot of air but some came out. It was quieter for a while but now its starting to come back. Does an airbound fuel system cause a rattle??
ZeroGravity58
1,401
51
Maryland
With a lift pump I would think you would have fuel running out if the housing was cracked. Only way i could see air getting in is if you had a leak before the lift pump where you had negative pressure.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
The housing always stays wet with fuel, never dries even if I spray it with Brake clean. And it was starting to take longer to start (crank longer)??? Until I bled it again???
Could it suck air without leaking a noticable amount? It doesn't leak on the ground but around the primer pump and bleeder screw is always wet.
DMAXDOC
May 26, 2011
119
Air would make it rattle IMO I think that you have a leak somewhere if it stays wet
Tank222
Feb 17, 2010
337
Frederick,MD
Little off topic but my truck is no longer holding rail pressure, and I think my bleeder screw is striped. Would that have any thing to do with it?
BlkMax
743
Wasilla, AK
For the record, diesel fuel is one of the hardest liquids to keep in a pipe. I have pressure tested piping with water, put diesel in the line, and had leaks. It may not be cracked, but something may not be completely tight, or leaking. Your bleeder screw may also be stripped (or have pulled threads) if you are using the stock plastic one.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Yep it got louder and louder, now it rattles bad again, what could cause this???? Im going crazy here. I wished I never touched it. Ran so good with the stock charger. I changed tyhe filter head Friday night, seemed great until Saturday night, the more I drive it the worse it gets. Runs great after I bleed it for about 50 miles. I do have the Nicktane filter adapter, Im going to take it off and just run a stock filter, I had to take the check ball and spring out of it so it will take the adapter.
13,712
772
Do you have a fuel pressure gauge? Maybe the pumps are going bad.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
I'm gonna go over to my buddies shop after work he has the big Kennedy gauge that reads pressure at the test port. Where should they be? If I recall mine were 5-6psi maybe 7psi max?
13,712
772
Somewhere around there. I'm thinking that if you're having a problem with the filter head, it should have a fuel leak rather than suck air unless your fuel pumps aren't working. That, or it's sucking air before the pumps. I don't know, just throwing it out there. I have seen a leaking WIF sensor cause a truck to knock/rattle and white smoke when you get on it, but it didn't have a lift pump.
