AMSoil diesel concentrate, cetane booster and cold flow improver in the winter. Diesel concentrate quiets down the injection noise quit a bit. Idles smoother and gets better milage.
My dad drives truck and when they order their fuel they have it partially mixed with Kerosene so it don't gel up. Would that hurt a DMAX?
this one? http://www.natbiogroup.com/docs/education/lubricity additive study results.pdf2 stroke motor oil, smooths everything out, brings up the btu's and sulfer lubricity. i run it in kubota, ingersolran, adn my duramax.. I've bookmarked a graft where it shows most additives, including powerservice kleen actually don't compare to the tc3 2 stroke, they have low to no lubricity.. but again I'm no mechanical engineer. but i know it works for me, and has for others for years..
You see the new stuff View attachment 6507 diesel concentrate & cold flow improver
who here runs w/o additional additives? Also if you don't run them, have you had any problems with gelling and where do you live at? thanks
I used to run without additives, I gelled at about -30C (-20F). I have been using Stanadyne ever since. Since then my truck has seen -46C (-50F) and didn't gel with the additive.
