front suspension
RichLMM
699
North Kingstown RI
Care to elaborate on hitch set up? Not trying to be a d/b just wondering. Anything to help on his truck would be awesome. It's a cab and chassis truck, lifts the front hard. Like pulls left front tire with 1000 lbs hanging off the front and torsion bolts out.
We r thinking about shackling the rear to help..
Thanks in advance
does the truck have a ton of rake?
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
How is yours setup vs. cummins killer? From the pictures I've seen of both trucks it looks like you both are coil overs
I'm pretty certain there's doesn't have coil overs on the chassis they've ran the last 2 years. It looks almost factory to me. Mine is dual coil overs with a cognito upper arm and Hsp made the lower.
RichLMM
699
North Kingstown RI
Not necessarily. Lots of succesful gas pullers run alot of rake. https://www.youtube.com/watch?v=o9KYKQFKnmQ
The guy in that video is a multi-time rwyb champion with full pull productions which is a very competitive organization.
I used to run my truck ass in the air and it wouldn't hook worth a crap I dropped the rear way down and picked the front up almost have it when its sitting still looking like its going down the track
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Not to insult you in any way, but some people can make one setup work and some cant. So you switch it and try something else and see if that works. I just posted that info so that clrussel wasnt instantly thinking oh crap we gotta change this rake b.s. asap because nobody has ever ran a truck like this and won.
kjp800
Aug 6, 2008
525
New Jersey
Yea you are right, I must have been thinking about a different truck.
bubba2400
Jul 19, 2009
199
Union Grove, WI
The way the hitch is mounted to the frame will dictate if the rake will work or not. So depending on how the complete package is setup, frame-suspension-hitch, it will change how well it works.
And remember, 2.6 trucks have four tires in the back, use them.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I think for the way this truck is set up we need to lower the rear.. It's worth a shot anyways..
bubba2400
Jul 19, 2009
199
Union Grove, WI
Make sure the hook point is as far forward as rules allow to take out any possibility of the pivot length being longer than a short bed. If the rules say that it has to be the rear most part of the truck you are screwed. Short bed trucks are shorter behind the rear axle.
Rich, sorry for messing up your thread. Pull the torsion bars and all the components to lose the weight then mount some coil overs in there. I would suggest to adjust the front suspension stops on the different tracks.
RichLMM
699
North Kingstown RI
no worries james! I like to see everyone get help if they need it...i'm just leary on changing my truck to much maybe i'll leave it be for now and see how my season goes
