Front ends
ikeG
Oughta Know Better
Apr 19, 2011
2,472
152
Western PA
www.facebook.com
We made it only one full season with the stocker. E Locker works flawlessly as long as its wired correctly and the hole thru the case is drilled at an angle away from ring gear. The ring gear bolts ended up nicking away at the wire insulation until it shorted them out. That's been our only issue(except when the slide collar busted).
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
Stock collar, stock cv's & air locker in the front
DHD spool & axles out back with billet adjusters.
not breaking :thumb:
I'd have to watch videos of your hooks but I'd venture to say maybe some set up things. I know tons of 2.6 guys running the same stuff I am with no issues. Mines just an old POS sand truck though
Rexarogers
Sep 23, 2014
Somerville tn
I had an elocker I used all this year and loved it. When switch is on, it is locked locked. Can't turn with it locked. But when switch is flipped off it's like normal again. Used it sled pulling and really helped me gain a few more feet.
I am going to pull out the differential this winter and go with a straight axle Dana 60 just cause it's a good deal I found. I'm going to sell whole diff assembler for $1000. That's the Cost of the locker and bearings itself. If your interested let me know.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
What gears are in it
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
904
31
Western MA
www.matpa.org
billet adjusters?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
An adjusting collar pushed the threads out of the housing, letting the spool cock a bit & the tearing up the ring & pinion. With the new housing I got billet ones and set it up that the adjusters carry no load with the threads. It is just a "spacer" now
So I'm guessing you tightened the f outta it so no backlash
TNRGreene
Kicked to the Curb
Sep 2, 2006
2,911
Bradenton, Florida
My DS side was cut down a couple thousandths & then shims were installed so that adjuster DOES NOT need the threads to keep it in place. It is tight to the housing on that side. It's like only having an adjuster on the PS.
