Reading this today, it almost sounds like there may be some moisture in the line. When they warm up, it expands and pushes the pads out. May a good brake fluid bleed on all four would fix it?
Seems so. A shop had to cycle the abs. Now it pulls left slightly. He said it was my alignment and front end issues separate from the brake problem. It didn’t happen before. I since replaced the rotors and pads in front and tire spins more freely. He suggested it as it looked like stress cracks in rotor. Not sure. I just put them n today and have not test driven it yet. Will do this weekend and report back.
Took it for a short drive and all seems well just like it was before this all started. It was either everything on front needed changed or the abs. It was odd that the rotor and pads were not old and had a lot of meat left. Maybe a bad caliper led to the rotor and pads heating up and warped. Not sure.
