OK guys, I drive a 04 duramax crew cab. about 3 years ago I got in an accident, went off the side of the road, (lesson for no txting while driving) hit an irrigation ditch and bounced off a tree stump. The stump smashed the aluminum skid plate under the truck and I blew 2 tires. the damage on the truck looked pretty bad, at the time I took it to a shop and they said if I told insurance it would be totaled. at the time it had about 100k on it. now it has 160 and a slight oil leak. So I crawled under to take another look at the oil leak and realized how bad the damage from the accident was. I've been driving it for 3 years like this and I'm not sure if I should just continue to drive it or try and fix it.
I do have a 1999 k2500 Suburban with a 454 big block in it. its seen better days has about 180k on it and it just sits, and needs a lot of work.
my question for you guys would be to fix the truck as it sits, and if so how, just keep driving the dmax till it dies with risk of the bent frame and a crack in the steering bracket, or do an engine swap from the truck to the burban...
any constructive criticism, or even "I'm a dumbass" is appreciated. but I just need some help
