*Fox Shocks* Need help please.
Tank222
Feb 17, 2010
337
Frederick,MD
OK thanks. I'm running the cheap fab-tech shocks so I'll look into some new ones. I really want to run the dual hoop setup, I have the parts, but took them off because of the cheap edlebrock shocks that were on it.
5,811
if you run the dual shocks, dont run a single off the LCA. it will be too stiff over all. I ran the duals with a set of the next step stiffer bilsteins on the shock hoop and no shock on the LCA and loved it. it work pretty well off road and gave a nice ride on the road.
Tank222
Feb 17, 2010
337
Frederick,MD
Ok i'm going to check into some shocks. The truck doesn't see to much off road besides the occasional ride through a field or check out something off road quick.
VVVJDMVVV
Apr 10, 2012
15
You wouldnt happen to have any pics of a 4" lift cranked down with stock rear suspension would ya ? I have been searching like crazy, not much luck.
5,811
I dunno if steve has any up but look up SSchmi5519. he has a cognito 4-6 decranked all the way and i think only a 2" block in the rear but its got a slant towards the front that way.
5,811
yeah, get yourself some good shocks. i jsut picked up some fabtech white bodys to get me by till i get my resi's. these thigns flat out suck
VVVJDMVVV
Apr 10, 2012
15
Ahh yeah I see his. Without the block in the rear I think it would have the perfect rake to the back im lookin for. Think I could fit 20x12 wheels on 33" A/T tires if I remove my bumper and have a pre runner/Skid combo like yours ? Or will I rub control arms more ?
5,811
your gunna rub the back fender under full bump or even 3/4 bump (as in, your suspension 1/4 the way from full compression). you need a much thinner wheel to do that. not even fiberglass fenders will allow enough room
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Dr.James...the rear of my truck is stiffer than rock. I have new bilsteins back there but it's so gosh darn stiff. Can you help me?
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Dr James. :roflmao:
To funny man anyway Sir Suspension James you do seem to know what your talking about but what I want to know is what fender are you running on your truck? Front?
5,811
Dr James. :roflmao:
:rofl: :D im running hanneman fiberglass fenders up front
come down here and ill give you something stiff ;)
5,811
Ill tell you what Mr they look F'n sweet!!!
Thanks for the info
Thanks mackin! truck IMOP is still too tall for the size tires i have and the big fenders but they may change in the next few months. should be able to lower it another 1-2" so the tires fill the fenders a bit better
