Has anyone here had any issues with the aftermarket cast or forged pistons in there d-max?
Melting?
Cracking?
Deforming?
Melting?
Cracking?
Deforming?
Melting?
Cracking?
Deforming?
What were your track times?i had 23,000 miles on mine and no cracking or melting and no deforming. ring lands looked great and they were checked by arias. dynoed over 700 and track time was over 800 hp with fisrt time tuning with new injectors.
I heard banks was only getting a few runs out of theirs before they had to be changed out cause they were melted.
I think Gale B. made a note on them that he thought it was because of the N2O. This does make the fire more intense.
He was also using the mahle pistons, IMO there second fidle to a true forged piston with better material to handle more psi and heat....
I have to respectfully disagree with the above statement. :hug:
Mahle "forged" pistons are some of the most technically advanced pistons in the world. Used by many Nascar Cup, Formula 1, and Lemans teams.
When you compare the engineering capability/capacity between Mahle (a world wide company) and the other manufacturers (20-30 employees each, located in the U.S.) it isn't even close.
Ross i know has made some very high hp 2500hp+ tractor puller pistons alone with a few others.
Thats cool, i think that when you factor in the ability to redesign and fine tune a piston to fit your needs a smaller company is allways more willing to help, also you cant argue with the cost difference, and material difference--it's not a one size fits all world. one other side is that not one of the top guys in top fuel or alcohol, or even pro mod engines are useing mahle pistons to my knowledge, and there heat and cylinder psi are higher that any of our diesel engines have seen so far in drag racing.
I dont know, i think that there is more than one good piston out there for diesels. Ross i know has made some very high hp 2500hp+ tractor puller pistons alone with a few others.
BTW the lemans cars are bad to the bone....
i have never heard of arias pistons failing in any diesel application, big boost, nos, propane......... sounds like a winner to me!!
Hmmm... so Mahle or Arias forged. Price like $2k on arias $3k on mahles?
