No blown belts. It sees the stick marsh mostly, put in off 512/60 sometimes running up to the backside of Kempfer's to the hunting camp.
How about a kit to "marine-ize" a duramax?
How ironic..We used to run the east side of 512 a bit racing w/ scotty cobb, and larry kesner..Have to let me know next time ya'll ride..I've got a 0540 Hamant boat that needs some time put on it.
Joey
Glad to hear Dan..My current prob is they are using a counter rotating prop 20 blades at 15* The gear ratio from flywheel to prop is 2.42to1 we hav a 2.68to1. the props are inforcing such a load on the engine that it's just choking it down and not letting the turbo spool, if you can believe that. A 510 Hp 502 will spin the same prop same * 400rpm more.. I can not get the d-max to build more than 17psi boost with these props set to this degree..I'm thinking it's something electrical, but am starting to have my doubts.. Some type of T/C would be perfect..
Any codes in the computer? What year engine and pcm are you using?
