can i reuse mine? i know my gm manual says to replace, but can i use them? if so, what method of torqueing do you use when the motor is out of the truck. how do you hold the motor down while torquing to keep it from moving around? i know the ones i have now are stretched. once used are they stretched too much to use again? what about using loctite and torquing less?
thanks!!
thanks!!
