The point I was trying to make is that the force on the breaker bar will be close to the same as if you were torquing a normal bolt over 300 ft lb.
To remove them? Why not?
The job is done But during the time before we got it off we snapped two Grade 8 bolts that we rigged onto a Ingersoll Rand air gun that has 550 Ft. Lbs of torque.
A quick heat with the propain torch did the job along with a 2' breaker bar and a 6' pipe on that. We snapped a stand that we had the block on, it almost fell but the hoist was close enough to help us out.
