Guys, yes I’m new to posting on here but not new to hot rodding, fabricating, materials science, or forums.
Now, to clarify: 1. All the big LLY Achilles heels have been fixed. No EGR, S&B elbow, intake, Rob’s trans safe tunes, coolant flush, thermostat swap to lower ones, Mike’s trans cooler, PCV delete, and so on.
2. Yes, I can build the trans. Yes, I understand at the scientific level why head gaskets warp/sheer or why studs perform better than bolts mechanically. Just because I haven’t done an Allison before doesn’t mean jack. I’ve done my research, I’ve talked at length with Mike, I have professional certified Allison techs from the Army that will help for beer, and a good friend with a bachelors in automotive technology.
However, we have strayed from the path. The original question was, Fleece 63, DT 64, or another good, mild turbo that’s gonna give me a solid edge over the stocker to better handle some hot tunes once the trans is built. I am not aiming for twins, at least not for 5-10 years when I do a whole engine with all the goodies. If the engine dies before then, I’m just patching until I get my SoCal stage 2-spec engine and then twins. Or triples. Or quadruples if that’s a thing then. Just like a Bugatti.
It's really all depending on what you're looking for. Personally, the only reason I'm looking at a 63.5 for my lb7 is simplicity from LDS cover and wheel combo and price. If you're looking at a quick spooling turbo, I think any of those will do. Personally I'd go a bit bigger for some more fun. I don't see the point of paying that much for a turbo that's not that much bigger than stock. I think an s467.7 or maybe a bit bigger would be a better option. Even an s472. With the right converter it'll drive great. Plus, easier to keep your bottom end in tact. Just my .02. Or even one of danvilles modded vgt turbos. Go big or go home :thumb:
Edit: so I just went back and re read everything. I didn't see the 68mm option to begin with. That's got my vote. Get the right converter and it'll spool great
