Def check the tuning to see if it can be turned up any more , and on the waste gate what kind of boost are you making ? when you say all the way loose do you mean closed / no boost feeding the waste gate actuator or do you mean full boost to it ? the MPH is decent depending on the weight of the truck , at that altitude with a crew cab I would expect to see around 108.5 mph-110 mph unless the truck is heavy .
