I have a 2003 Duramax Quad Cab with an LB7 and am looking at a motor/Allison combo that the owner is not quite sure what model he has LLY or LBZ (he bought it used and only has the motor/trans).
I was able to do some digging with the Bosch ECM number: 12606127. When I looked up this ECM it showed that it belongs to an LBZ. In addition the MFG date on the ECM is 10/10/2006 which would again lead me to believe its an LBZ.
This is critical because the LBZ ECM and the LB7 TCM are not compatible. I would need the whole motor/trans combo in order to make it work in my 03 Max.
The last part of the equation is if the rear housing on the trans is a 4x4 or a 4x2. I am not sure from the picture I have seen. If you could take a closer look and tell me what you think. I believe the rear housing can be swapped with my 03 and it should work if it is a 4x2.
Thanks,
Andrew
Thanks,
Andrew
