Well my first sled pull this season is tomorrow. Think I got the truck set up good, let me know what you think.
Dropping the tbars all the way down.
Spring clamps on front and back of leaf springs.
1,000 lbs of weight to add to the truck.
285/75/16 on pyro half tread good year wrangler mts.
Going to run 30 psi in the front tires and 50 psi in the back tires.
Air bags are going to have 90 psi in them that will put my hitch right at 26 inchs.
Going to crank the pressure up on my lift pump to try to help me hold rail pressure.
Question is with my built trans do I want to run tow/haul mode or leave it in regular mode and use my lock up switch?
