First pull fail
Janimal444
354
Salem, NH
Either go back to stock height or go with a 4" lift so you can crank the torsion bars down and have level CVs. I like to have mine cranked down even further and then when on the throttle they will level out.
4" Cognito kit may be your best bet, as you can run your current wheel setup. Tuff Country is a nice lift, but I believe you'll have to run a different wheel with a negative offset for that lift.
whitelmmmax
Smaller than stock
Jul 26, 2011
693
lake charles, la
Ok well I guess im going to aim for a lift and put the stock keys back in and get the allseasons bracket and I should be good to go.
You may want to call and talk to Tony. From what he says his brace will not work with a lift kit. But I would still call him and talk it over with him.
5,835
You can NOT run tonys brace if you put a lift kit on. Hes said that in a few different threads before.
Imop, if you wanna pull cheap. Ditch the lift keys, and buy tonys bracket and a new idler pitman arm as im sure they are shot.
If you want to spend some money, ditch the lift keys, buy either the dmax stores full centerlink kit or Super Diesels new centerlink that lets you change between setting for steering and run a set of cognito braces with new idler/pitman are.
Only my second recommendation will work with a lift kit
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
:eek:I snapped a CV on the track and it definitely did NOT result in my tires looking at each other... like was said you really need to address that front end before you pull again.
Also, the reman CV that the autoparts stores sell are stonger then the new aftermarket ones that are even thicker.
ask me how I know
Max Attitude
11SIX
Mar 7, 2012
814
Caledonia, MI
Well i just bought a new napa one, lifetime warranty. I dont plan on breaking another one, gonna fix the issue. If Tony's braket wont work ill probably at least get the cognito braces.
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
Yea that warranty aint worth a god damn thing, apparenty for one to snap in half it must of been "abused":mad: I went in circles forever with those idiots and they wouldn't give me anything
616samuel
Apr 26, 2011
178
Rockford, Michigan
There's a lady who pulls with us at MTTP that has a 4"lift and does very well, my truck is stock height with the bolts completely out... both work great, i just don't have the turning radius she has when we hang weight lol. She does tend to break more drive shafts than me though hehe
timlb703
Aug 20, 2007
145
I have a tough county 4" lift fully braced with custom tie rod ends set up for pilling or dd. $700.00 shipped if it helps. Nice came off a flordia truck. Always said I am going to use it on a truck of mine but never have.
Janimal444
354
Salem, NH
Do you have any pictures or anything of the components? I might be interested, although I was thinking of going with a Cognito so I could run the same wheels I have. Good price though.
Max Attitude
11SIX
Mar 7, 2012
814
Caledonia, MI
Its going to be a little bit before I buy a lift but that is a pretty good deal. Would the tc lift work with my wheels? They are -12mm offset and I think 4.53 backspacing.
Drew92
Aug 31, 2011
23
Here's a 4" tuff country lift with suspension maxx keys clocked lower thank stock. Truck is running 33x13.50's with 20x10's and he doesn't have to drop it to pull or race.
