First hook of the year.
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
What tires and what pressure are you running . Any chance you can run a smaller rear block in the rear. I like my truck to run level if not a touch nose high going down the track.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Curtis- Tires are TSL Boggers 33x14-16.5 on 14" rims (@ 30lbs this time out). I've tried to run a 2" block instead of the 4", but the nose goes higher then the rear. With the 4" block it's pretty level down the line until I lift. I'm still using the stock hitch, just moved forward about a foot. Possibly a better hitch point or different locker other then stock in the rear? It would be nice to gain another 15-20'. Been thinking about a converter un lock too. I kill it at the end every pull.
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
Tires are TSL Boggers 33x14-16.5 on 14" rims. I've tried to run a 2" block instead of the 4", but the nose goes higher then the rear. With the 4" block it's pretty level down the line until I lift. I'm still using the stock hitch, just moved forward about a foot. Possibly a better hitch point or different locker other then stock in the rear? It would be nice to gain another 15-20'. Been thinking about a converter un lock too. I kill it at the end every pull.
14" rims??? Or you mean 14" wide tires
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
you may be surprised how your truck pulls with the front end a little nose high. i used to pull my rear down against my stops to get the desired ride hight. what pressures are you running? also track conditions? if its a loose track from what i saw you can get away with pretty low pessures. ive ran as low as 25/15psi rear/front bias.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
I usually run down to 20lbs all the way around, but I drove there and back so I left them @ 30lbs. I'll drop the psi this weekend and see how she does. Everything around here is 3" sand then hard packed dirt. This next weekend will be the tightest hook with clay/dirt.
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
Sounds like you have a good handle on your set up. Dual tires would help a ton. Sts work great on loose tracks.what gearing are you running? You may be over spinning you tires if you are tuning high rpm's. I run 456's and turn about 42-4500 down the track.
JakeBrakeIH
Dec 24, 2010
406
Yaphank, NY
STS Im sure would bring your RPMs down and def hook a lot more. Derek06 switched from boggers to sts and dropped about 400 or so RPM's. Truck was night a day difference going from boggers to sts...
