Watch a few others run first and get a good idea of where the staging beams are. Things look allot different when you pull up to stage than they do from the sidelines. Rig up some spring clamps right quick before you go and clamp the front of your springs. If your running PPE level 3 you can launch at about 1000 rpms and hook pretty good, anything over that and your just going to blow the tires off.
