Are you talking about an 01-02 front bumper or an 03-06 GMC bumper?Yes. If I replace the bumper because they hacked it up then I'll go with a GMC one
No plans on making it look funky. Bit I do like the look of the GMC front end better and was thinking if I have to replace it all then could I swap over. Still kinda getting ahead of myself as I don't even have the truck yetNo, please dont do that. ^^^ It doesnt look right. You should be able to remove all the bracketry from the current bumper and reinstall on the new chrome metal bar. You can buy bumpers all day long online.
As for interior pieces, its all yard stuff, 1500 or 2500 the same. I did find the 01-02 "black/dark grey" interior pieces are just a slightly different color than the 03-up. Everything will fasten the same, though.
As far as I know. There are no laws for individuals bringing their own vehicles in. I think they are only preventing dealerships and manufacturers from selling them here. When one brings a vehicle from out of state in, DMV doesn't care one bit what emissions compliance it is. They just want to know the vin matches the paperwork and weight of the vehicle. They will often have you bring the vehicle to one of the offices so they can match the numbers and make sure it's correct in their system. Then they want to see the printout from a dot certified scale so they can calculate the registration fees.I'm not familiar with all the laws of California when it comes to emissions and registration. Obviously an LB7 truck that was originally equipped with EGR and cat must still have the equipment in place and functional, but is it legal to bring a federal emissions truck into the state and register it? I assume when they were new, you weren't allowed to do that or they wouldn't have made different versions in the first place, but maybe it's ok to own and drive them in the state but not sell them?
I think it's only 3 cars a year and then you need a dealer license after that.
FYI, the Key is not to get flagged in there system. Make sure the person testing it corrects it before submitting it to the DMV. Once you get flagged, They start taking a closer look. They can end up sending you to a state ref for an inspection to clear it up. He will pull out his book and look at everything they info on including the operating system and the CVN's... They will look at everything visible and make sure its OE or OE replacement legal...
With the current way they do the OBD2 inspection, it records what is in the ECU at the time of the inspection...
Chevrolet | 1998-2005 | DIESEL C/K2500 & C/K3500 (including Silverado and Suburban), G30, G3500 (including Sport Van, Express Cut-Away & Cargo), P30 | Federal diesel vehicle over 8,500 GVWR is not OBD-II certified. | Federal diesel vehicles over 8,500 GVWR were not built to comply with OBD-II or Fed OBD standards. | Test normally. BAR-OIS will ignore incomplete continuous monitors. If the vehicle fails to communicate, use the result of the bulb check for the overall result of the OBD Test if the analyzer offers this option. |
??? I thought tier 1 didn't have an EGRMy Kodiak (lly) is a federal emissions truck with tier one phase out emissions. From some of the reading I’ve done, if the EGR falls off it doesn’t set any codes. Which I guess falls in line with the smog place putting in the right info.
Sorry, I had to look again. It was emissions system federal, tier 2 phase out (NT9 rpo). But the same applies. As Dave covered.??? I thought tier 1 didn't have an EGR
