How do I find a boost leak? I'm at the track and can only hit 35 psi on a big tune. I've checked every boot.
Jeromy did you datalog the runs? Does it feel like its kinda laying over? Give me a call if its still giving you trouble.
If you aren't cleaning up all your smoke with a single CP3, you probably have a boost leak.
Once the turbos are all spooled up, do you see any smoke at all? With a single stock CP3, the twins should clean up all the fuel you can throw at it.at the track in 4wd there is minimal smoke, on the street in 2wd, there's a good puff when I flog it. Is this what you mean? For a while now, I've had this feeling about my intercooler..........no reason just feeling. I haven't installed the BAnks CAC pipe, waiting on boot.....
How are the EGT's?
I sent you a PM
At the line building boost, it's hard to get 5psi, so when I leave yes there's smoke, other than that I can only see a light haze, may be darker/thicker from outside the truck though.Once the turbos are all spooled up, do you see any smoke at all? With a single stock CP3, the twins should clean up all the fuel you can throw at it.
I taped the intake manifold... put and hooked the air compressor right up to it... I sealed the inlet of the turbo. Also get some soapy water and soaked whatever area you feel is suspect. My EGT's IIRC did not increase with my boost leak at all... Not saying boost leaks don't increase EGT's just giving you my experience. 35 psi max is very low... If you made 65 psi now makw 35 it must be a boost leak or mechanical problem.
