Finally the truck is running right.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Shit, just throw that batmo on the shelf and run the 88mm as a single. You know what the turbine size is on it? I bet you would make more power that way.:thumb:
The thought is crossing my mind to use it as a remote mount single. Would that turbine work as a single?
Its the 92mm turbine Rob. I blew the same up pipe at this pull... What are the chances of that lol!
You know more about my turbo then I do. :thumb:
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
What converter?
Precision makes a t-4. 96 housing for gt4. It will be tough to lite but with your loose track I bet you could stay on top of it on the big end. I know rob tried a similar charger of johnboys and it wouldn't lite until like 3200 rpms.
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
What converter?
A lot of their big turbines they wont make in t4 anymore... they said too much restriction. Mine now is bigger than Johns, turbine and compressor, and clipped to 2.6 i can light it at around 3300, but my converter stalls to that pretty easily. Actually i can light it about 3k when the conditions are right, and i have enough heat built up. We made some good changes after platte city, and instead of setting on the line for 2 minutes it only takes me around 30-40 seconds now if that.
