Chop saw for the exhaust and a band clamp or something to hold them together at the downpipe connection. Even with a reducer I'm not sure the stock hot pipe will be tall enough, may require cutting and welding a section or buying a hot pipe made for that (ATS or custom).
A bung or some way of installing the MAF.
LB7 Y-Bridge and cold side pipe.
New tires and a diaper.
im gonna weld the downpipe to the front pipe FTW! im not sure it will be long/tall enough either, if not i can make an extension but i know a guy with an s472 and his stock hose reached so im hopin mine does.
my intake has a MAF spot
i plan on getting cold and hot side pipes down the road. really dont wanna mess with the y bridge haha
im gettin new tires in a couple weeks....
i was honestly extremly confused....Ayooooooo :roflmao: :spit:
I'm a ****ing dumbass.
But on that note...if you havent deleted the IAT (Intake Air Heater), that is a huge restriction you can remove.
Question....my pedestal has studs for the up-pipes, will the up-pipes be able to slide onto the studs without having to remove them from the manifolds? do they flex enough?
