Finally gettin twins!!!!
Power Shift
Apr 22, 2010
68
Utah
IIRC i'm pretty sure you have to pull the trans dipstick to get it to come out the top. Its a tight fit for sure but you can get it out in one piece without cutting it, at least on mine i did. Good luck man i feel for ya
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I was beating on the top of his downpipe for 15 mins with a hammer and a 4" metal pipe for it to come out :rofl:
It did "gracefullly" come out. :D
6,123
As of 6:30pm az time shes is breathing through twin turbos! Just waitin on trent to send me a dsp5 tune and its off to play. Boy that was a damn chore lol. Shock hoops all modded, inner fender is sorta formed to the down pipe lol. Got a very tiny leak at the valve cover where the fitting bolts in but i didnt teflon tape it ( completely spaced it). Just gunna tape that tomorrow. Otherwise shes definitly idles a bit quieter and will spool up quick if you power brake it ( the two black marks on the concrete will back that up lol). So excited to go play now!
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Time to change your signature :D
6,123
Just sent that tune over James so you should ready to rock and roll :D
Thanks trent! Ill call ya tomorrow about how shes runnin. Its got a rattle like a powerstroke and the throttle has like a dead spot when you first push it
Congrats brother time to bomb some desert
Yeah boy! Not quite though, hose clamp on the coolant res broke so gotta get one of those and the exhaust is rattling on something
Im all over it lol
6,123
heres the pics.
brian tryin to get under my hood. poor guy lol
brian acting like hes workin
teh ratchet strap we used to finally yank the damn down pipe out, what a bitch to do
bare passenger side engine compartment. pretty much where we stopped friday night.
hot pipe in!! kinked the damn a/c line though its still blowin cold, we will see this summer i guess. Also bypassed the stock fuel filter head since i have a airdog II
exhaust housing and down pipe in, you can see it hits the shock hoop. it needed to drop down another 2 inches to meet with the hot pipe so we took the shock tower out for the time being
the big bad boy setting in place
chopped up intercooler pipe.
and back together! fits like a glove
side veiw of how i did the oil drain and ran the lines.
here she is all together!!! oh so beautiful
and the twin turbo stickers go on :D:D:D
pic of the inner fender and how i did the shock hoops (pretty much jsut cut off the tabs and re-welded them to the outside of the shock tower), came out great!!
And now its time for bed lol :coolspot:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Kick me a log over of both , where its rattling and catch the dead spot should be easy to fix , looks good now you just need to detail the motor up nice , truck looks great , front end looks mean :cool:
6,123
Looks awesome bro...making me want a lift even more :D
haha im tellin ya, your gunna like it from all you keep tellin me you do! we will probably be doin a trip to the dunes in mid feb or possibly mid january if you still want that kit my buddy has.
Looking good..... Did you heat and form the inner fender liner? Its hard to tell from the pictures
sort of lol. i formed it around the pipe but since my shock hoop is so close to the down pipe, it pushes the liner into it so i have a good feelin im gunn have to cut the liner out around the pipe
Looks awesome Bud!
It's tough working under the hood with a lift tho Tony....I'm thinking about taking mine off.
that i can vouch for 100% but pullin the tires and setting the frame on low jack stands makes it much better (i just didnt have any jack stands free for my truck lol)
Will do trent! Also noticed she smoked like a son of a gun this mornin when i first started her. Detail will be comin this wednesday so i can get the truck washed and clean all the pipes
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
Congrats :thumb:
Keep an eye on everything for the next while and retighten clamps etc.
And have some fun :D
6,123
Congrats :thumb:
yeah thats teh plan after work. gunna get some logs for trent and check everything over again (went over the damn thing 4 times last night lol)
btw, how do you guys have your little boost valve deal set? (the adjustable deal that goes on the stock trubo wastegate line). i havent put mine on yet :eek:
TrentNell
Jul 7, 2008
7,543
slc tuah
I just sent you that tune back with the timing we used in your last one so that should help , the dead peddle I will need that log though , on the regulator turn it all the way tight ( arrow pointing to "off" ) , then loosen it a turn at a time then test , go as far as you can until boost starts to drop then go back up just a hair.
