filter and pump info needed
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
Im trying to gather parts for my fuel system, i am going to use one of the aeromotive pumps that we normally use in our 6.0 and 6.4 fuel systems. the major problem is that the pump is a -12 line so i need a filterhead that is atleast -10 so flow to the fuel block isnt restricted and the pump doesnt burn up.
On the ford kits we pull the fuel through the 2 micron filter then pump, with the picky lb7 injectors i dont want to chance it and not filter after the pump.
anyone have any ideas?? i thought maybe i could just put the filter after the pump but the manufacturer says its not reccomended.
ripmf666
15,123
14
47
Wentzville Mo
I'm thinking of something from my race car setup. and it should work for you just have to look up the part numbers all from Jegs or Summit.
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
havent really had the time to do anything with this but i need to get something done, stock filter head is leaking..
anyone know of a good filter/filter head setup with at least a -10 inlet outlet, hopefully 2 micron with a water seporator?
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Cat 195-1068 filter base.
1ea 326-1642 water sep. filter 10 micron
1ea 1R0749 fuel filter 2 micron
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
what size inlet outlet, reason im really wanting at least 5/8(-10) is im not getting any positive pressure on some of the bigger tunes, i will be adding a bigger pump but i cant justify that if i add a filter setup that is going to cause a bunch of restriction.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
-12 o-ring boss I think, the black lines in the photo are 1/2" so I had to adapt down. I can get the exact size once I go to work tomorrow.
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Donaldson P562262 is what I run. Its has 5/8" inlet/outlet and I run a CAT 1R-0749. The filter head will flow 180gph and I forgot what the filter will flow but it will flow more than I need.
-Shep-
RCLB kind of guy
May 4, 2011
75
Tennessee
I keep CAT 175-2949's here at the shop. They are completely enclosed with a drain valve. From what I've been able to search, you should be able to use that instead of a 326-1642 that has the spin on bowl...right?
BTW, nice set up BurnDown.:thumb:
