Lots of pullers ran filled block with stock heads. Knock the freeze plugs out of the back of your heads and circulate water thru them. Wont even need much of a radiator, maybe none at all. You could cut the thermostat housing legs off and tig AN fittings to them to plumb it all.
You dont see it much anymore with the solid head from wagler but it definitely has worked.
