Fifth wheel and a lifted truck
hrlyguy2
Dec 2, 2011
274
IL
Anyone have a lifted truck towing a fifth wheel with out issues.
Looking at a fifth wheel top of my bed rail is 63 inches.Concern about issues
z79outlaw
793
37
Salem WI
The axles are often times flipped on the trailer depending on the size of the lift. Essentially going from a spring under axle to a spring over.
hrlyguy2
Dec 2, 2011
274
IL
So his truck and his trailer would have a lift?:rofl:Sorry Mike i had to do it
I have seen some trailers that have lifts on them.I wouldn't want that. think it would be unstable at 10k lbs unloaded .
Somethings I like that are top heavy and its not a trailer:angel::D
Jan 30, 2011
59
Sacramento ca
no not all i went up from a 235 tire to a 31 toyo mt tire with a 11 in wheel so the tire is 2 in wider and works great i cant tell much difference from when both were stock
Jan 30, 2011
59
Sacramento ca
ony pic i got but this was with 4 in blocks and the stock 235 tires hope it gives you idea. it would been perfect with 6 in lift
hrlyguy2
Dec 2, 2011
274
IL
I'm confused. You said you had a 37 inch tire 9" lift.
But you went from a235 to. 31 that gave you enough to be stock height.Do you still have the. 5-6 inch clearance on the bed rail
05Redlly
Feb 24, 2010
13
Iowa
Ya..um...Don't mean to be rude here, but with a rig like that with that set up, I think we as forum followers are entitled to alot more pics of that truck and trailer set up. Really nice dually!
