fifth gear failure
duramaxloui
Mar 6, 2009
5
dallas
i was testing my new gauges yesturday when i floored the truck around 70mph the truck didnot down shift like normal but at about 95-100 the tranny just lett go and i red lined i put the truck in neutral and back in gear and it worked fine any ideas
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
how bad is a limp for a truck i have heard alot about this and never none the extent of damage
a limp is when the trans senses a clutch slip and disengages before further damage is done . it will limp easier ,and easier after each time . but if the power is turned down it will operate like normal usually . wich is why most say turn down the power or get the trans built .
no codes no lights, and i have had a limp before and this seemed nothing like it
i would scan it , sometimes you pop codes and the MIL wont show on the dash . it can not limp without a code . the code is what causes the limp ( or disengagement)
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
"Zing" IIRC (been awhile...)
Which is prelimp.
Better start saving for and read-up on aftermarket tranny upgrades!
dbtravis
is rattling my brain out
Jan 25, 2009
251
Michigan
mine did that, shut the truck off for 5 minutes and it drove fine. other then that annoying light
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
that happened to me yesterday. i was racing a porsche and it kicked into what i though was limp mode, so i started to slow dow to pull into the shoulder and it all of a sudden fixed itself and shifted back into 5th... so i kept it moving. no cels or codes.
then again this morning goin to merge onto the parkway it actually went inot limp mode. i had to pull over shut the truck off and wait 30sec for it to go back to normal. i started it back up and had a cel. then kept it moving again.
duramaxloui
Mar 6, 2009
5
dallas
well i havent had a limp mode in a long time but my tranny seems to be running a little warmer than usual i was wandering if anyone has one of those magnet oil pans and if it actuly reduses temps
