Yes, I'm gonna get cap screws tomorrow to clean it up a little more
wouldn't it overheat?
i thought the fuel that goes through it cools the ficm and keeps it from getting too hot
3 reasons:Why did you move it?
I like it! Did you have to extend any wires or just remove the wires from the loom?
Both What a frickin rats nest in those looms
I know, Im going though the same stuff And I want the ficm in the cab
How about you cool it with washer fluid, a small fish tank pump and your in da business
I'm missing something here. Cool what? Cool the fuel? All I did was move it, it will have the same under the hood temps like before. I'm lost
Unless the lly's are different, the lb7's have fuel running through the ficm to cool them since they run on such high voltage
You mean because the fuel lines are looped together? That's not done yet, I'm hooking those back up
Fuel flows through the FICM to keep it cool......That is one off the issues of running a lift pump over 14psi, it blows out the seals in the FICM.
I get it, yes thats why me and Simon keep asking about the cooling.
There has been discussion since the fuel runs thorugh the ficm and the fuel temp can get pretty high that the ficm might process faster and run smoother if it was cooled by something other than fuel
