Not sure if this is the proper place to post this, so I apologize in advance.
I have my truck 99% back together after head gaskets and studs but I would like to flush the cooling system now. What I plan on doing is pulling the block drain to drain anything that is still in the block, fill the entire cooling system with distilled water and something like prestone cooling system flush/cleaner and take my truck for a good long drive. Then drain that and fill it with 50/50 dexcool and distilled water. My question: is this a good procedure? Or does the dexcool act as lubrication for the cooling system?
I am also going to go back and retorque my heads like the cummins guys do.. After how many miles should I go back to check them? I planned on lightly driving it for 500 miles or so, then going back. I followed ARP's instructions to the T, keeping the studs "hand tight" and torqued the nuts 60-90-125 in their given sequence, but I read on another diesel forum after the fact that guys let the studs sit over night to "stretch". In my opinion, going back to retorque is easier than doing gaskets again due to a "stretching" stud.. Any input please, Thanks.
