fastest stock lmm
2,042
Would you guys all agree that no matter the Duramax version, you're going to have to run a low-12.30 to even be considered fastest stock-turbo?
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
I believe you are correct. I think Moss went 12.34 IIRC in his stock LB7 about 3 years ago.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Yup I agree that's why I'm going for 12.20's weighing 7060
you are so high it isn't even funny, maybe at 6600 that # is possible you'll need over 600hp to do it it isn't going to happen at 7000# my little amigo ill bet you money... seriously... I'd like to quote my good friend Billy Bob Thorton, "Wish in one hand, shit in the other and see which one fills up first."
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i have to agree here , there is only so much air/fuel availible to make power , you have a bit more fuel but air is not availible . you can probably run a bit faster than your 12.56 but without trimming down i dont think you will get to 12.20 @ 7060 lbs .... @ 6600 lbs yes...
and whatch out for the nay sayers if you end up that quick @ full weight better be ready to prove the bottle was out of the truck .jmop
reuter
Slow and Smokey ;)
Feb 4, 2009
42
Somonauk
Im pretty certain the 12.34 was on his A5K on a single cp3....i cant remember how he did with the BD turbo, but i know his fastest time to date was with the A5K on the "Date Truck" :rofl:
wikdlmm
<-- OWFA
Jun 27, 2008
1,974
san angelo
i said it once ill say it again... im the best there is nobody can hang with my stuff. i wake up in the morning an i piss excellence!;)
gmduramax
Shits broke
Jun 12, 2008
4,087
254
Nor cal
I did a 1.7 60ft on the 12.56 if I drop it to a 1.6 it should be faster than a 12.4. I figure I need to make close to 570 to get 12.20's
I will have the bottle disconnected just to make sure :)
paint94979
Beer Nazi
Sep 18, 2006
11,715
Anthony your thinking although optimistic is not correct, because you go from a 1.71 60' to a 1.69 means you will go from a 12.56 to a 12.53 not 12.49. Also with those wheels and tires you are never going to 60' good unless you switch back to stock or make more power. Your only hope is pulling weight which these amazingly gifted Diesel Addiction champions are going to do. .
gmduramax
Shits broke
Jun 12, 2008
4,087
254
Nor cal
Anthony your thinking although optimistic is not correct, because you go from a 1.71 60' to a 1.69 means you will go from a 12.56 to a 12.53 not 12.49. Also with those wheels and tires you are never going to 60' good unless you switch back to stock or make more power. Your only hope is pulling weight which these amazingly gifted Diesel Addiction champions are going to .
I plan on going from a 1.71 to a 1.60 ;) My tires hook good :confused:
Im not pulling weight ;)
Also I plan to be 600rwhp by the end of summer
paint94979
Beer Nazi
Sep 18, 2006
11,715
Why don't they hook as good as mine?:D Why didn't you get a set of wheels and tires that were small and light? 1.60 huh Russ runs Drag Radials and doesn't even cut those numbers are you racing on planet Earth? or Neptune? Earth is the only number that counts.
gmduramax
Shits broke
Jun 12, 2008
4,087
254
Nor cal
They hook better than yours. You cut 1.6's because your turbo spools faster than mine
paint94979
Beer Nazi
Sep 18, 2006
11,715
My turbo spools faster than yours??? You are high again it has NOTHING to do with it. They key to 60's is power to weight ratio my PW/WR is just better than yours. You have way too much rotational mass to 60' at your weight maybe lowering it might help but there are only 2 ways of going faster... more power or less weight
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
I cut 1.59 on cheaters in my measly 12.36 @ 108 truck. Your 60' is power, weight, and traction - I've race and seen alot of cars with 500+hp and ALOT less weight that can't 60' what our trucks will, some that pull a tire. All the power in the world won't 60' without enough traction to use it. If you have all the traction in the world and not enough P:W you will have a bad 60' as well. At my weight and power level traction was not my limiting factor, at those cars weight and power level traction was their limiting factor.
We didn't strip any weight from Mike's for the 13.2 - actually we put a toolbox in his bed for traction:joker: on top of the extras he has on his truck
I am lucky to get Winston to drop the tailgate and toolbox - his seats have never been out, his bumper and beefed up hitch have never been off.
Chris runs without a spare all the time and take off his tailgate and his extra seats to race - not exactly all effort stripping
Mine is the most anemic since it has no spare and a rollpan with no hitch and I remove the seats.
You guys are all more than welcome to strip weight.
The 4WD LMM I'll be tuning and trying to help hit 12.4 or better with will not be local and I'll have no control over what he removes. He did say he bought it as a cab chassis truck - so to get back to stock he would have to remove the bed :joker:. But he'll leave the bed he put on it in place.
To be continued........
2,042
Ok, so we've determined that Moss ran 12.34 in his LB7 reg cab, and other than the Spruills, thats the LB7 stocker "record".
Who are the "recordholders" for the other 3 Dmax versions so far? I figure someone must know.
Skintback went 12.39 in his LLY.
