FASS vs. Airdog????
mpr3369
Nov 18, 2011
3
Ended up picking up a FASS 150 Titanium. Does anyone know any Fuel filter and water separators that will work with the fass 150? Cat, Baldwin, Napa ect.?
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
The Cat 1R751 fuel filter (2micron absolute) can be made to fit the Fass just like the AD from what I understand.
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I make my own with Raptor lift pumps Thanks to Burndown
Is that one filter on the suction side? you have to be careful about cavitation because those pumps are not designed to pull much psi on the suction side before cavitating.
Also, i don't believe the raptor has the ability to remove air from the system. It would just compress the air down the lines to the CP3 if it cavitates.
Rudy1
Jul 6, 2016
55
Illinois
Pumps
I was on some other forums and they were all saying it was Fass that had bad customer service. I don’t have either yet but am in the market to get one. Thanks for the read
036.6turbo
715
I bought mine NIB, second hand, the guy bought it and never installed it.
Right after I installed the check ball assembly stuck and the pump blew the inline fuse.
I called FASS, and has a replacement check ball fitting in (2) days. No questions asked.
I have no experience with AD.
