When you install a draw straw and get away from the factory pickup, does the Fass cease to be a flow thru pump, what i'm getting at, is if the pump dies for some reason, is the truck dead now
Is there a larger pick up that you can get if so where?
I have a fass pump with a draw straw type pickup and it works just fine when the pump is off.
My fass is not flow thru at all
