this truck has been a project and now I need more help
if you keep the rpms below 2200-2300 rpm it will run fine, if you put it in park and rev it up it goes as high as you want without issue, but if you go over the 2200-2300 rpm range will driving it completely loses all power, the truck has complete egr delete, def delete,and cp3 conversion, tuning done by motor ops, we had this issues 2 weeks ago and motor ops had me unplug the throttle valve, it fixed it for a bit but now is acting up again, we plugged it back in it ran fine a couple times then we start acting up, we removed the flapper from the throttle valve that didn't fix it, I do have some data logs of it acting up and not acting up if some knows what they are looking at.
thanks kevin
thanks kevin
