I have a lb7 with 281k on it with all original parts from the day it was new and it has died on my and makes roughly 250psi cranking over. It returns about 150ml to the tank on a 15 second crank period. I have it on a gravity feed system to eliminate air leaks and it'll drain a quart bottle in about 2 hours. I started ripping apart tonight and pulled the rubber line off the cp3 that's kinda in an L shape 3/8 in size and fuel comes out of it. Is it a sign of a failed CP3? Thanks!
