Help: F%^*& electrical crap. Help please!
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Ok I've got the multimeter wired in to the negative batter cable with only one battery connected and it's reading a 0.47ma draw. I checked the alternator and no change there. Now to pull fuses. Lowest amp fuses first yeah? Or does it matter?
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Think I might have found the culprit. I pulled the radio fuse and the draw dropped down to 0.05ma. I have had an issue with the radio not turning off every once in a while if I turn the truck off with the door open then shut the door but it's intermittent at best. Completely forgot about that. Think it may be whatever gizmo controls power with the door open/closed?
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
You are truly great and powerful. Haha
So 0.47ma isn't enough to kill the battery? So it's probably the batteries then?
PACougar
2,105
41
El Dorado Hills, Ca
I'm nothing special, I've just been through it before. 2 good batteries shouldn't die overnight with that kind of draw. Every time you kill the batteries they hold less power each time, so they may be at the end of their lives. At least if that's the case you won't do it to the next set.
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
I've never had a battery, much less two Optimas go bad that fast. Granted while I was deployed the truck sat dead because the starter was bad (wife ran them down trying to start it). Really not excited about buying new batteries after just getting a new starter. Granted that starter lasted over 100k miles so I guess that isn't so bad.
I really appreciate the help guys.:thumb:
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I had terrible luck with the optimas in my last truck. First one was junk after about 8 months. You could leave the door open for 5 minutes and the interior lights would drain the battery enough for it to crank slowly. Autozone replaced it free of charge and the guy there said it wasn't uncommon to see them fail. The next one lasted aboutt he same amount of time before I traded the truck in and started seeing similar issues.
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
I wish I had an amp clamp. All I have is a multimeter. Both batteries were tested separately.
Had the same problem. Turned out to be the pass seat switch stuck in full back position, it's common. You don't need an amp probe, just get a 12 volt single filament lamp, like a turn signal bulb, and solder some wires and clip leads on it. Connect it between one of the + batt leads and the batt, place it where you can see it and start pulling fuses & relays one at a time. Don't forget the relays under the dash by the steering column and in the end of the dash on driver's side. When the lamp gets very dim you've found the circuit that's causing the problem. Good luck.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
You said a year old? I would think 2 year free replacement warranty. It's probably that wiring harness thing to connect an aftermarket stereo. I had one go bad and the radio stayed on.
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
Seriously? I thought Optimas were supposed to be the bees knees or whatever. Fooled me I guess. Kind of an expensive whoops though.
I'm definitely going to be taking the radio out to check the harness and see what's up.
Anyone know what triggers the lights or whatever when you open the door? I'm not seeing any kind of button in the door frame that would be stuck.
03spoolindmax
Nov 9, 2011
674
Mi
The door latch itself has a connector that goes to it to trigger the radio off and lights. There's also a button on the headlamp switch that can be pushed to either have the lights come on when the door is opened or not come on at all.
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
OK, now more electrical crap. Just driving down the freeway and my security system, battery and cruise control lights come on, my fuel gauge drops to zero (there's definitely fuel left) and the cluster is reading zero oil pressure. Can I chalk this up to crap batteries too or is this something else?
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
Possibly a bad cluster. Although, as far as I know, usually just the stepper motors go bad causing false gauge readings.
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
The gauges actually work. I actually replaced all of the stepper motors about a year ago. I turned the truck off for a while earlier, turned it back on and all was right with the cluster again. I was just assuming thos has something to do with my crap batteries.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Actually just got back from the store to buy one. Now I just have to figure out how to use the dang thing. I pulled fuses for a good half hour. What am I supposed to set this thing on to read the amp draw? Never used one before and the directions leave much to be desired.
Did you make sure and get a DC one? Klien makes and AC/DC one very handy.
jlawles2
1,067
Danbury, TX
