Ok, I'm at my wits end trying to figure this out on my own, so hopefully y'all can help. My batteries are consistently draining over night. It starts just fine with a jump start, and the batteries both get a load test of 13.98v after it's been running for a while. I just replaced the starter yesterday because that sucker was just old and worn out, and I've added an aluminum fuel cell where the spare tire used to be so I'm not using the factory sender any more. I can't find any loose ground wires or shorts. I've checked the usual rub spots anyhow, but I put them in some extra loom a long time ago to prevent it.
Is the fuel level sending unit constantly powered, or just when the motor is running?
