I've been happy with my 4" mbrp. I agree with the previous posts about the performance gains. I'm glad I changed my downpipe because I did seem to drop some egt's but I mostly like it because the exhaust sound is deeper and the screech is gone under heavy throttle.
x2
Thanks...I take it the turbo back is more benifical than the cat back? I see Diamond Eye has a 5" no muffler turbo back for 322.00. Or would it be wise to run muffler?
Ditching the cat will also help lower EGT's.
I ran both 4" and 5" on my 05.... preferred the sound of the 5". After replacing the downpipe, it sounded 10x better as well as a slight SOTP pickup in responsiveness. I fit the 5" on my truck when it was lowered with no issues... the only spot it comes close to hitting is the trans crossmember and it still cleared that with a 1/2-3/4" of room. However, yanking it out to put the cat back in for smog time was FAR easier when the truck was lifted. Gets kinda tight in there, shoehorning a 5" pipe between the body, trans, framerails and crossmembers.
I ran without a muffler, preferred the sound. It never annoyed me until I put the topper on, that caused an echo that could be heard in the cab. Got used to it, and eventually tuned it out.
edit: forgot to add, the above may have been because the exhaust dumped at a 45* over the differential.... may have been the cause for the echo. Normal exiting exhaust may not do that.
