Exergy 60s, what to expect?
nc-12vpower
Mar 25, 2013
41
NC
For the price difference you cant beat 100s, allows for alot of adjusting down the road if you ever change the setup.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I debated 60vs100 for a while and now I have had 60s for the past year. Ordered 100s Tuesday. I thought the 100s would be smokey but my 60s run so clean I think the 100s will be just fine
andy-stevenson
Jul 7, 2013
838
How much does cold weather affect larger injectors? I live in Canada and the truck will see -40* temps and just wondering if it's even possible to run 100s?
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I think 100's will be ok, but for a stick bottom end, stock fuel truck my tuner recommended 60s. He said If I thought I may build the engine in the near future to go ahead and get the 100's so I'll only have to do it once. I know all tuners have different opinions but he said its a little tricky on the really low HP settings for a dsp5 setup. My smallest tune now is probably around 400 hp? and to get down that low with 100's would take a very small pulse, under 1000? not sure but I know it would be small.
LWATSON
Jul 30, 2008
2,587
55
Scotland Neck NC
Its been a while but I finally got the truck back. I ended up doing a few more things and it just took time. The truck seems to drive about the same but not quite a clean as with the stock injectors, I'm sure that's normal. I can tell a difference on spoolup especially when I go full throttle. Once it starts to spool it ramps up almost instantly now. Also when Im building boost for a 4x4 launch I can get boost up very easily, before wasn't bad but now it comes up faster.
dirty_max
815
eureka il
notice any power gains? looks like you went 60s. stock cp3? im in the same boat, except I need bigger injectors so I can make more powa!
LWATSON
Jul 30, 2008
2,587
55
Scotland Neck NC
Stock cp3 here, my peak power feels about the same but it comes on sooner and ramps up quicker. Definitely a more responsive, funner to drive truck.
